JT2Go embedded
Is there someone who knows if its possible to embed JT2Go (or any other TCVIS product) within a Web browser?
Regards Rolf Emdevik
Re: JT2Go embedded
Hello Rem,
yes it is possible with JT2Go freeware, but it is old browsers add on.
Bonfiglioli in Italia use it for presentation of their products.
You can download it from this web site:
http://www.bonfiglioli.com/en/industrial/customer-support/2d3d-drawings/
It is also helpful to download the pdf file with instructions from there.
The Siemens support for it is years ago.
You must not register at the web page at Bonfiglioi, this is only for their own products.
Have tested some month ago the jt2go web viewer and it runs, but it is not very comfortable.
As an example, if you will scale up or down the view in the IE browser you need to config the html file.
Hope this helps a bit.
Wolfgang
Re: JT2Go embedded
Thanks Wolfgang!
But do you think you can help me a bit to make this running. I downloaded the pdf and jt2go.exe, but i dont understand how this can help me test jt2go in embedded mode? the jt2go.exe seems to be the general siemens jt2go application.
Regards Rolf
Re: JT2Go embedded
Hello Rem,
if you run the JT2go. exe Setup it install in the folder of Win IE explorer.
After intstal start the Win IE explorer.
In the PDF file you find the IE settings for viewing.
You can drop an JT-File into the IE browser window.
If all settings right it shows you the "blue" JT2Go window with your file.
It works only with IE not with an other browser.
best regards wolfgang
Re: JT2Go embedded
Hello Rem,
have forgotten some Info for you, the JT file must be converted in version 8....
9 or 10 JT Files are not running.
What is JT?
JT is the World’s Most Widely Used 3D File Format for PLM
JT is the common language of PLM and is the world’s most widely used 3D format. JT is the first ISO International Standard ( IS 14306-1) for 3D visualization and collaboration. Compact and accurate, JT is used throughout the product development lifecycle in all major industries to communicate the critical design information typically locked up inside a CAD file.
Siemens PLM Software customers rely on JT to be the most robust 3D visualization format available.
JT Open Factsheet
JT Open Member Resources
JT Open Documentation Technology
JT Open File Format Technology
JT Open Toolkit
Downloadable viewers for Windows Desktop, Windows 10 Universal App, Android and iOS.
Download JT2Go for your platform today Download JT2Go Desktop 64 Bit all languages
Download JT2Go Desktop 32 Bit for English
Windows 10 JT2Go Universal App
Android JT2Go
iOS JT2Go
