JT2Go on IOS hangs while open files
I try to open a jt file (exported as single file from NX10) in JT2Go version 1.1.0 on IOS.
I use itunes to move the file from the computer to the ipad. Afterwards the file will be shown in the bookmark list. So far so good. Selecting the file is will not open and JT2Go 'hangs' always working, but doesn't show the file. I try with a simple block.
Any idea what went wrong?
Try to send the file by mail - same problem.
Thomas Schulz
Siemens PLM
Re: JT2Go on IOS hangs while open files
Siemens Genius Siemens Genius
Siemens Genius
Hi Thomas,
Do the samples work for you?
Mike Z
Sorry for not response on time. I found the solution by my own.
It depends on the export setting using on the NX side.
I even forget which is needed at the end, because I tried different settings and then after some rounds it works.
Thomas Schulz
Siemens PLM
