JT2Go within Teamcenter Enterprise 8.1
Good Day All,
Our customer requested a demonstration of JT2Go integrated within existing Teamcenter Enterprise 8.1.
Unfortunately any installation on customer desktops is not allowed, ie. everything has to go through the web browser (Internet Explorer).
We have downloaded a desktop version on our local VM's, loaded the test model (Turbo Charger), however we are unable to find any plug-in for web browser.
There is a link JT2Go Desktop - Upgrade to Teamcenter, however that seem to be more a marketing page:
http://www.plm.automation.siemens.com/en_us/products/teamcenter/plm-platform-capabilities/visualizat...
Is this possible, we would appreciate if someone could point us towards right direction.
Thank you
Re: JT2Go within Teamcenter Enterprise 8.1
Gears Legend Gears Legend
Gears Legend
It is no Web Viewer App with JT2Go gettable.
Best option is to use 3D-PDF if your customer has Adobe Reader.
Very old JT2Go Version has a Web option.
Or you use LiteBox3D from TechniaTranscat.
https://www.transcat-plm.com/software/techniatranscat-software/litebox3d.html
But if you find a JT2Go Web based Viewer I be interested too.
Hope this helps a bit
Wolfgang
Siemens Genius Siemens Genius
Siemens Genius
JT2Go is an app so does not run in a web browser. As is noted, very early on JT2Go was an ActiveX program that did run in a web browser only but that did not meet many users needs. There is not an option to connect to Teamcenter with JT2Go, Best to use Active Workspace for those workflows.
Mike Z
Thank you all for your responses.
It looks like the customer will have to choose the other option.
Cheers
Atos
