JTCmd to Clipboard - Stop copying Jtcmd automatically - Vismockup
In Vicmockup 11.2, How to stop JTCmds from automatically copying to the clipboard when activating model views or when selecting parts in the viewer.
Whenever I select a part in the model view, a JTCMD//.... command is saved to the clipboard and this affects the excel work I do simultaneously.
Is there any way to deactivate the setting by any chance? This problem was not there in previous versions.
Re: JTCmd to Clipboard - Stop copying Jtcmd automatically - Vismockup
Siemens Legend Siemens Legend
Siemens Legend
There is a fix which was released in TcVis_11301_a01_patch_2 last week.
It is also going to be fixed in TcVis_11231_a01_patch_7 due out next year.
The workaround to the problem woudl be to edit your registry and set the following key/value pair.
Set the following Value/Value Data in
\\HKEY_CURRENT_USER\Software\Siemens\VisView\<version>\<Product>\<language>\CurrentProfile
\\HKEY_CURRENT_USER\Software\Siemens\VisView_Retained\<version>\<Product>\<language>\CurrentProfile
Value Name:URIClipboardMode
Value Data: 0
For instance for VisMockup 11.3 in English, the Registry areas would be:
\\HKEY_CURRENT_USER\Software\Siemens\VisView\11.3\Vis Mockup\C\CurrentProfile
\\HKEY_CURRENT_USER\Software\Siemens\VisView_Retained\11.3\Vis Mockup\C\CurrentProfile
Thanks Rick. I will try this.
