Open JT file in Browser
Hi Team,
We have JT File  and we need to view those 3D images in Browser.
We need to build a similar page  like below. When we click on image it should open and view the 3D view.
http://www.plm.automation.siemens.com/jt_showcase/jt_showcase.shtml#webViewer
Please let me know if you need any other information. Do we have any DLL/API to open this file using .NET ?code
Please help me. Thanks in advance.
Re: Open JT file in Browser
Siemens Legend Siemens Legend
Siemens Legend
I am forwarding this onto the PLMVisWeb team - they are responsible for the JT Showcase WebViewer.
Rick
I am the development manager for the PLM Vis - JavaScript toolkit.  We produce the WebGL viewer and APIs used to render the 3D models in the browser.  Please feel free to contact me for more information.
Best regards,
--Mike Turner
michaelturner@siemens.com
How to get the JavaScript Toolkit file?  do you have any document to how to use the Toolkit.
Is there any cost for the Toolkit?
Please let me know how can i contact you to proceed further...
The PLM Vis JavaScript toolkit is currently part of the larger PLM Vis toolkit (which includes Java and Active-X components and APIs as well).  You need to purchas PLM Vis in order to obtain the JavaScript toolkit.
The JavaScript toolkit itself does include a full set of documentation:  Getting Started, Developer Guide, Deployment Guide, API documentation, etc.
You can contact me at the following e-mail address:  michaelturner@siemens.com
--Mike
a free way is also possible.
Use JT2Go Desktop 11.3 and save it as HTML.
You can also modify the background colour.
I do not like the blue-green.
For this you can modify the home.css
Example:
/* viewer color.*/
#component {
    background: #ffffff; /* For browsers that do not support gradients */
    background: radial-gradient(circle at 3.52% 8.74%, #085078, transparent 100%),radial-gradient(circle at 47.72% 96.69%, #85D8CE, transparent 100%),radial-gradient(circle at 50% 50%, #5c5f61, #5c5f61 100%);
    height: auto;
    width: auto;
Best Regards
Andy
why can I view the JT HTML file only online and not offline?
Best Regards
 ...Christian
Siemens Legend
You currently need to be online, as there are urls in the html which are trying to use stylesheets and javascript for display and functional processing.
<link rel="stylesheet" href="https://appsforoffice.microsoft.com/fabric/2.1.0/fabric.min.css" type="text/css">
<link rel="stylesheet" href="https://appsforoffice.microsoft.com/fabric/2.1.0/fabric.components.min.css" type="text/css">
<script type="text/javascript" src="https://code.jquery.com/jquery-2.1.4.min.js"></script>
We'll take a look to see if we can rework these dependencies which will allow you to view these files in an offline mode.
Rick
Hello Rick,
thank you for the information.
That would be great if offline is also possible.
 ...Christian
