PMI not displaying in plane properly
Siemens Creator
I have just exported a JT our of NX 11 and some PMI is not aligned to the viewing plane properly. I checked it in NX and it is fine, any clues?
Re: PMI not displaying in plane properly
Siemens Legend Siemens Legend
Siemens Legend
If you can attach the file to this thread, I can forward it onto someone who may be able to provide some explanation.
Rick
Siemens Creator
How to I attache the file, I try an it errors about incorrect file type?
Zip and attach the file.
Ganesh
Siemens Creator
Here is the file
Siemens Legend
I see the same results in TcVis 11.2 and 11.3 (which JT2Go is based on).  If you are able, please log a IR/PR against Teamcenter Visualization for this.
Rick
Hi @Gary_Gorman,
I have checked this in NX 11 viewer, it shows the FCF in correct orientation (Top View) but seems that some data is missing. Also checked this in JT2GO 11.2.3 and TC Vis 11.2, same issue as you shown.
Ganesh
