Solid Edge Viewer / JT2Go
Hello together,
how we can install and work with Solid Edge Viewer 8 Desktop and JT2Go 10.1.5 Desktop at an Windows PC? Have try the old way from UGS (Siemens) already to use the iSeriesInstall.bat, but this do not fix the problem anymore. Same Problem is existing with insight connect 8 and JT2Go 10.1.5. It always pops up the message “please make sure your program is installed correctly” when I try to start Solid Edge Viewer 8 or insight connect 8.
(see attached file)
Re: Solid Edge Viewer / JT2Go
Here is an Link to an Answer I get from our SE Support.
This solved this problem too.
http://community.plm.automation.siemens.com/t5/Solid-Edge-Forum/How-to-Install-JT2Go-10-and-Solid-Ed...
What is JT?
JT is the World’s Most Widely Used 3D File Format for PLM
JT is the common language of PLM and is the world’s most widely used 3D format. JT is the first ISO International Standard ( IS 14306-1) for 3D visualization and collaboration. Compact and accurate, JT is used throughout the product development lifecycle in all major industries to communicate the critical design information typically locked up inside a CAD file.
Siemens PLM Software customers rely on JT to be the most robust 3D visualization format available.
JT Open Factsheet
JT Open Member Resources
JT Open Documentation Technology
JT Open File Format Technology
JT Open Toolkit
Downloadable viewers for Windows Desktop, Windows 10 Universal App, Android and iOS.
Download JT2Go for your platform today Download JT2Go Desktop 64 Bit all languages
Download JT2Go Desktop 32 Bit for English
Windows 10 JT2Go Universal App
Android JT2Go
iOS JT2Go
