VFFrame error trying to load files into JT2Go
I am trying to open jt filesin JT2Go and keep getting the following error on every single file (including the samples).
VFFrame Version 10.1 32 Bit has stopped working.
This is a Windows 8 system with 64 bit and JT2Go 10.1.2.
Rather exasperating and any suggestions will be appreciated.
Re: VFFrame error trying to load files into JT2Go
Siemens Legend Siemens Legend
Siemens Legend
This post was just brought to my attention and I see that there are people still having a problem.  My first suggestion (if this hasn't already been done) would be for you to uninstall the version of JT2Go that you have on your machine and download/install the latest 64-bit version available (11.4.0.4) and see if you are still having the issue.
