VisJT2GoOCX ha detected ans invalid lincnse key for this install.
I installed JT2Go 10.1.5.15309 32bit version.
I am developing WinForm program include JT Viewer.
I added VisJT2GoOCX to WinForm.
When I run this .exe file, Error is occurred as "VisJT2GoOCX has detected an invalid license key for this install. Unable to continus.".
Let me know how to view JT in WinForm.
Regard.
Re: VisJT2GoOCX ha detected ans invalid lincnse key for this install.
Siemens Legend Siemens Legend
Siemens Legend
You cannot use the VisJt2GoOCX outside of an office integration solution.  It can only be used within MS Office applications.
Does this mean you CAN use JT2GO inside the office VBA environment (Alt+f11 in any office app)?
Kind regards,
Thomas Musters, Virtual Reality development for Design & Engineering, ASML
Production: {NX9, VisMockup, Unity}
Development: {C#, Java, VB} Testing: {-none-}
Siemens Legend
Not that I know of.   You can use JT2Go 10.1.x (32-bit ) in 32-bit Office documents:  Word, PowerPoint, Excel.
VBA is a development environment available inside of word (excel, powerpoint, etc), to add functionality to documents, so technically inside of the document since your developments are saved as a .docm document
