conversion of .jt file
Hello, I have .jt file of a tank and would like to convert it into a format which Creo can open and save. I tried saving it as NX .prt file and open it in Creo but "this part cannot be retrived" message pops up. Is there any other solution for this?
10 REPLIES 10
Betreff: conversion of .jt file
Hello @gannuagastya
I am not familiar with Creo now please can you name me your possible import format types.
My first thinking for converting is to use cad assistant from open cascade.
With this software, it is possible easy to convert JT data.
https://www.opencascade.com/content/cad-assistant
Best Regards
Wolfgang
Re: conversion of .jt file
You should be able to export out to a VRML 1.0 file the extension is .wrl. Creo can open .wrl file format.
To clarify I am assuming you have access to Visprofessional or VisMockup
My ultimate desired format is Creo .prt file. I cannot do that directly in Creo unless I buy the JT extension. So next best option would be anything that Creo can open without losing the data(like STEP, IGES or parasolid). But I keep losing some parts of complex assemblies when saved in one of these formats.
Siemens Legend Siemens Legend
Siemens Legend
Sounds like your trying to do something quick, there are a lot of products available that will address your situation, including products from Siemens. Perhaps you should look for a free trial to get by your current situation. Trying to work through a series of derieved formats is not going to be very satisfieing.
Mike Z
Hi @zinkm
yes you are right, it is a good point.
I have forgotten to explain if you need more than only the graphic you need other software for it.
You can catch with the tool only the graphic.
Best Regards
Wolfgang
Re: .jt to .cim
Hello, I have .jt file I would like to convert it into a format which cimstation can open and save.
Thank you
Re: .jt to .cim
Hello @Shareef,
please let us know which file formats you need for import.
Best Regards
Wolfgang
You can export the jt file in STEP (stp) format and then you can open the file in creo.
