open JT file
I've received a big JT file (about 300 Mo) and I can't open it with NX 10. After several hours the windows "WORK IN PROGRESS" is still there, the proccesus ugraf.exe is running but nothing happens.
Is there some optons or tricks to open such a file?
thanks in advance.
Re: open JT file
Siemens Genius Siemens Genius
Siemens Genius
You might try opening it with JT2Go, if that works then the problem seems to be with NX. If not you likely have an issue with the JT file.
Mike Z
What is JT?
JT is the World’s Most Widely Used 3D File Format for PLM
JT is the common language of PLM and is the world’s most widely used 3D format. JT is the first ISO International Standard ( IS 14306-1) for 3D visualization and collaboration. Compact and accurate, JT is used throughout the product development lifecycle in all major industries to communicate the critical design information typically locked up inside a CAD file.
Siemens PLM Software customers rely on JT to be the most robust 3D visualization format available.
JT Open Factsheet
JT Open Member Resources
JT Open Documentation Technology
JT Open File Format Technology
JT Open Toolkit
Downloadable viewers for Windows Desktop, Windows 10 Universal App, Android and iOS.
Download JT2Go for your platform today Download JT2Go Desktop 64 Bit all languages
Download JT2Go Desktop 32 Bit for English
Windows 10 JT2Go Universal App
Android JT2Go
iOS JT2Go
