2 Jack working synchronously in TSB in Jack 8.0.1
Hello all,
I want to create a simulation scenario where 2 Jack will lift a heavy component together and keep it at a specified location. Is it possible to create a synchronous activity both Jack are dependent on each other?
Re: 2 Jack working synchronously in TSB in Jack 8.0.1
Better do this in Process Simulate/human. it is much much easier than doing in TSB.
Old jack is always making you frustrated...
I have a similar problem, how is it possible in Process Simulate Human?
I manage to make Jack2 do a task only after Jack1 completed his task, not simultaneously.
Many thanks in advance.
Siemens Legend Siemens Legend
Siemens Legend
In PS you can create a simulation either using the "Task Simulation Builder" or the old legacy human operations. Please see the attached video showing how to create a simulation for the humans with TSB.
If you are more interseted in the old legacy operations, let me know.
The key is to pay attention to the:
General Task Parameters -> Occur After/Before task
To create the new task in the correct sequence order.
You can also use e.g. the Wait task in order to modify the sync between operations.
Also make use of the TSB task context menu: Add TSB task before/after
-> in order to automatically set the "occur after" property.
(view in My Videos)
Thank you so much, your video explains exactly what to do.
I solved my problem by simply setting the current Task Simulation Builder (es.TSB_Simulation_1) in the field "Occurs after".
Many thanks
