Animation of objects attached and hold in Jack7.1
Hello all,
I'm using Jack 7.1 Animation Module. Imagine Jack lifts a box and during the lifting scenario his grasp posture changes. He holds the object, then after a specific height he needs to grasp from different points.
I use "foot prints" to attach the box to him. Once I change Jack's posture or grasp points, the footprints and attachment feature are lost. I create footprints again. Is there any workaround?
Thanks a lot,
erol
