Do you mean
Reply
Solved! Go to solution
Changing the camara path for a simulation
Hi All,
When I export to animation, how do I change the camara angle as the animation is being created?
I am trying to follow the camara around the avatar as he does what he needs to do.
Thanks in advance for any help offered Smiley Happy
Solution
Solution
Accepted by topic author TMS
‎08-26-2015 04:32 AM
Re: Changing the camara path for a simulation
Hi TMS,
You can make the camera movements part of your animation: Animationwindow>Scene.
If your simulation was built with TSB, then I would export this animation first (TSB window>Results>Export to animation system) and then add camera paths to your simulation and export it as a movie.
Gert Nomden
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
Many thanks for the reply. That has helped greatly.
