Climbing Stairs in TSB
Hello People!
I need to make Jack climb onto a platform and then simulate assembly operations using TSB.
Any ideas on how to make him climb??
Re: Climbing Stairs in TSB
Siemens Genius Siemens Genius
Siemens Genius
Are you using Jack or Process Simulate?
In both tools there is something called the 'Elevation Transition Module', which can be used to simulate climbing stairs and ladders.
The steps needed to combine stair climbing with a simulation are slightly different for each application.  Can you let me know which you are working with?
Hello Christina,
We are using Jack 8.3 to simulate the Human activities. We are using Task Simulator Builder to create the operation animation. We tried using the Elevation Transition Module, however, we are unable to link the module with TSB.
