Configuration support xbox 360
How we will configured xbox 360 kinect sensor  to Jack 8.3 on the Win 8.1 ?
Re: Configuration support xbox 360
You need to use Kinet dedicated sensor for PS integration. NOT the one from XBOX. looks similar but different. if you use XBOX one. system will not recognize it at all.
Thanks for the answer...
Siemens Legend Siemens Legend
Siemens Legend
Just to clarify, it must be a Kinect for Windows v1 sensor. The original XBox Kinect sensor will also work, but you will need an external power adapter. The computer USB port is insufficient to power it.
UlrichRaschke
Hi Ulrich,
do you know if there is support for any more recent releases (besides the v1) of the Kinect to be expected?
Siemens Legend
Microsoft has announced the next generation Kinect for Azure. We are working with Microsoft on support of this device, though we do not have an availability date set at this time.
UlrichRaschke
