HMD supported in Jack
nowadays, what are the HMD devices (head mounted display) supported in Jack?
kind regards
Re: HMD supported in Jack
Not sure. I would call GTAC if you have not found out anything yet. It seems calling is always best thing to do. I am about to do it for some of my questions.
Since you mention the Oculus in your tags, I can tell you the Oculus isn't officially supported yet, but you can set it up as a secondary display. You then miss the barrel distortion though.
However, there is a program for the oculus rift called Virtual Desktop that allows you to apply barrel distortion manually.
Barrel distortion example
Hope this helps,
Thomas Musters, Virtual Reality development for Design & Engineering, ASML
Production: {NX9, VisMockup, Unity}
Development: {C#, Java, VB} Testing: {-none-}
