Jack Static Analysis Help
Hi all,
I am a college student who is new to Jack and using the student version. I am looking to simply do some static analysis on my models, each of whom have loads placed on them by clothing, holding objects, etc. I can't find any documentation as to how to do the analysis once I've added these loads. Could anyone point me towards documentation or tell me which drop downs or tabs it is under? I found the user guide really convoluted.
Thank you!
Re: Jack Static Analysis Help
Siemens Genius Siemens Genius
Siemens Genius
The ergonomic Analysis tools can be found from the main toolbar: Analysis -> Task Analysis Toolkit.
If you're unsure which is the best tool to use, or are looking for step-by-step instructions, click on the HELP option in the same menu.  There is a chapter dedicated to each tool, with a tutorial for each.
I hope that helps!
Christina
