Jack set up
I downloaded the student version of Jack. I got the link and the license file but I couldn't figure out what I should do. I couldn't find a way to use license file either. Which steps will I follow?
14 REPLIES 14
Re: Jack set up
Hi All,
Has anyone else had difficulty setting up the license server?
When I choose the license, it tells me that the license is invalid.  I replaced the License.dat file as instructed in the Tecnomatix Jack Student Download instructions.
Help is greatly appreciated.
Re: Jack set up
I needed a license to install the license server called splm6.lic
Took me hours to find it
This shouldn't be that hard,
Thomas Musters, Virtual Reality development for Design & Engineering, ASML
Production: {NX9, VisMockup, Unity}
Development: {C#, Java, VB} Testing: {-none-}
Re: Jack set up
Has jack program supported by Win 8.1 ?
Re: Jack set up
Yeah, Jack works on Windows 8. I am currently running it on there.
Re: Jack set up
Siemens Genius Siemens Genius
Siemens Genius
For Jack v8.4 (latest release) ->  Win7 and Win10 64 bit are the officially supported windows platforms. Windows 8.x is assumed to work.
Christina
Re: Jack set up
windows 8 or windows 8.1 ? which  ?
Re: Jack set up
when will you release to it (Jack 8.4 )?
Re: Jack set up
I'm sorry, I misspoke. I am using Microsoft Windows [Version 10.0.10586] (Windows 10 Pro) to run Jack 8.4. So way above 8.1
Re: Jack set up
I can not find Jack 8.4
can you help me where I find Jack 8.4  and
I can not find detailed documents  Smiley Sad
it is very important for my project
