Looking for Procedure to Import custom Anthropometric data into Jack
In addition to the default anthropometric data that is available in Jack we would like to add a additional data. As per the release notes of V6.0 this is possible through python script. We located the script which is available with the Jack Installation and the same is attached herewith. I was looking to understand if someone has performed this import in the past and if so what is the procedure. We used the command of source to try and import the sample file initially. Looking for help on this.
Re: Looking for Procedure to Import custom Anthropometric data into Jack
Siemens Genius Siemens Genius
Siemens Genius
Hello Rohit. Please see the attached document that describes the steps to register new anthropometric data with Jack.
UlrichRaschke
Hi Ulrich,
I am not able to find the attachment. Kindly request you share it once again. Many thanks in advance.
Thanks & Regards,
Rohit S Mallya
Siemens Genius
Sorry - seems it might be a browser issue. Trying Chrome...
UlrichRaschke
Thanks Smiley Happy we were able to import the new data into jack..
