Performing simultaneous TSB task using two human
Hi ,
         I am currently working on a simulation involving two jack performing various TSB task.At certain instance i want both the jack to perform different TSB  tasks simultaneously. Is it possible to do ?
PS: When i tried performing simultaneous task by modifying the start time in the sequence editor one of the TSB tasks gets executed while the other remain stationary.
Re: Performing simultaneous TSB task using two human
Siemens Legend Siemens Legend
Siemens Legend
It is possible to have the human perform their tasks in parallel.
When creating the tasks - take a look at the lower section of the TSB UI.
There is an Occurs After/Before task field there.
New tasks are by default linked after the previous created task.
When you create a task for a different human you may instead want it to be created "first" in the simulation.
In that case select the parent TSB Simulation node itself as the Occurs After task.
If you want to reorder existing tasks you can do that by following the steps shown in the video below:
(view in My Videos)
Best regards,
Pelle
Thank you PelleAberg !
