Do you mean
Reply
Solved! Go to solution
RLLA and REBA
I just wanted to ask if Jack RULA analysis cover also for RLLA and REBA analysis. If not which will be the way to perform such?
Thanks in advance!
cortega@interlatin.com.mx
+52 (81) 10801310
InterLatin S de RL de CV
Solution
Solution
Accepted by topic author InterLatin_Sim
‎09-29-2016 10:34 AM
Re: RLLA and REBA
[ Edited ]
hello,
simply, REBA is RULA with added focus on the legs. As far as I know, Jack does not include REBA, but you can take RULA output and add coefficients for legs from body position. In Process Simulate Human it could be obtained simply from Generic Analysis.
If you use Jack you can write your own script, that coputes REBA score.
Dave
