System requirements for Process Simulate Human
Hello everybody,
can someone tell me what are the system requirements for Process Simulate Human?
I am using it for a while now and the long loading times (up to 10 minutes) between to tasks in the TSB are really anoying.
Now I thought it maight be the perfomrance of my computer which causes all the trouble.
I´m using a 64bit Windows7, 32GB RAM, Intel Xeon CPU E5-1630 v3 @ 3.70GHz, Nvidia Quadro K2200 4GB
I thought that should be enough maybe not.
Greetings
Roberto
6 REPLIES 6
Re: System requirements for Process Simulate Human
Hi Roberto,
I may have faced a similar problem with TSB. In my case I had quite some constraints between tasks in place. My suggestion would be to contact the support desk.
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
Hi Gerd,
Thanks for the advice.
Do have any information about the system requirements?
Greetings
Roberto
Siemens Legend Siemens Legend
Siemens Legend
Hi Roberto,
Are you able to share the data with us?
We are aware of some PS TSB performance issues, these have been dealt with for the next 14.0.1 release.
It would be interesting to see if your problem falls in the same category, or is rather some other issue.
Best regards,
Pelle
Hi Pelle,
unfortunately I cannot share this in here.
But I´m in contact with Stephan Schulz the Software Product Consultant.
I think us three have had a skype meeting last week anyway.
Greetings
Roberto
Hi Pelle,
I figured out that the further I get down the line of TSB tasks the longer it taks the software to load, not only the changes I made, even the simple klick to open a specific task.
Greetings
Roberto
Also I think it writes a lot of data into the catch. The reason for me to think that is because, if i start the whole PS all over it works faster.
