TSB Go task creation
Hello Guys
I am a new person for Jack simulation in PS Software.
when I created TSB for "Go task", jack can only go in the "Default Posture ", if I changed Jack location or Posture, it can not running Go task, not sure I expalain clearly or not .
such as below posture I want jack go ahead
but after creat GO TSB, Jack revert back to defalt posture below
can I know how to fix it?
4 REPLIES 4
Re: TSB Go task creation
Siemens Legend Siemens Legend
Siemens Legend
I am not completely sure - but it looks like the environment may be loaded "upside down".
TSB will work properly only in an environment where the positive Z direction = up.
Is it possible for you to rotate the environment 180 degrees, so it matches Jack's idea of up and down?
Then retest the GO task creation ?
Best regards,
Pelle
so your mean is we only can create the resource and environment in Jack's positive Z direction = up?
and all the resource should match with Jack only, if we want to use TSB?
not able to change jack to match other resources' Z direction?
Siemens Legend
Right, if possible please rotate "the world" so it corresponds with pos Z = up.
Some commands will work fine also when Jack is rotated upside down, but TSB in general will not.
Best regards,
Pelle
Thanks, Issue closed base on your direction, but hope in Tecn v13 can be done some improved
