Walk issue in TSB
Hi all,
We are having a little issue with Jack when using TSB to create walks. We need Jack to move laterally in a tight space. So walking should actually just be about taking some side-steps.
However, with a Go-task the manikin first takes initial steps forward, then turns around and moves to the destination in many steps. The same happens when a Get-task is used. This not only violates a collision constraint but it is also far from realistic.
So, the big question: is there an option to create these smaller sideways movements in TSB?
Gert Nomden
Gert Nomden
Senior Consultant | Tecnomatix Product Manager
cardsplmsolutions.com
Re: Walk issue in TSB
I have this problem too. There is no one who is concerning with the customer's problems about Jack. I use demo version, i would suggest this software to my compay for buying this software. But I see that there is no adequate solution to the customers.
