What is the practical way to attach object with weight on human body in Jack ?
For example, carry backpack or equipments or uniform.
Weight of the objects are included when analyze Lower Back Analysis.
Is it possible to do this ?
To only attach object to human, weight is not considered in analysis tools (Am I right ?)
Thank you very much.
Re: What is the practical way to attach object with weight on human body in Jack ?
first of all I should confess, I am almost new with JACK, but I hope that my answer can Help you, as far as I understood, you mean that, how can be the weight of your object be considered in Lower back Analyse on body of the Human. Am I right?
In the case of static experiment, you can go to Human Contol/ Add Loads an weights and there you will be able to define the weight of your object to different parts of Hand of JACK, for example to the Palm Center of your desired hand(right one or left one) and as soon as you did that, you will see its effect in your graph in Lower Back Analyse.
In the case of dynamic experiment(for example making an animation in TSB) before starting to make the animation you can right click on your object, and then TSB, and then define weight of object.
Sincerely yours,
