cannot import objects into Jack
Hi guys
I have a student version of Jack software. For my master's project I need to explore a certain scenario where human modelling can be used. Mine involves a car... At first I thought I could import this from the jack library but there aren't any cars.. then I thought I could import a file, as long as it matches one of the file formats that Jack reads, but also no luck... it keeps giving me the interface error. I have tried reinstalling but that does not help.
if anyone else has encountered the same error and knows a solution, please help !
5 REPLIES 5
Re: cannot import objects into Jack
Siemens Legend Siemens Legend
Siemens Legend
Sorry you are running into the issue. Can you share what file type you are trying to load and what error you are getting in the Log window? Can you attach the file for us?
UlrichRaschke
Hello !
thank you for replying and of course, screenshot and the file are below, no copyright btw, I am using files that have a free license attached to them
Siemens Legend
Hi LauraB,
We tried to load your file, and it works fine for us. Can you attach your Jack log file and the contents of the import log window? They may contain clues as to what is going wrong.
UlrichRaschke
ERROR: can't read "_jsIOD(stl,clean,toggle)": no such element in array
Siemens Legend
Hi Qodar,
Which version of Jack are you using? The Trial and Student versions should both be able to read stl and wrl files up to a 700 segment limit.
UlrichRaschke
