Data Structure and Data Upload to MindSphere via MindLib
Community Manager
Since the MindConnect Nano can only send float, boolean and string variables to MindSphere, is it possible to define own/other data structures with the MindLib?
-> The Lib offers you a Blob upload with which you can basically upload any data type into MindSphere, you then merely need to create a custom parser.
If you are a MindDeveloper, you also have access to the Siemens Industry Only Support extranet where the MindConnect Lib documentation is stored. You can find further extensive insights into the Lib there.
