2 pcs Flat-Patterns in 1 model ?
Hello
This model has 2 pcs of Flat-Patterns ?
  1. # Seems old version. Is it corrupted ? Not updating why ? Is the link disconnected ?
  2. # Second one is looking right and updated
1 REPLY 1
Re: 2 pcs Flat-Patterns in 1 model ?
Sometimes it happens that a flat pattern view is not deleted when a new flat pattern is created.
I've not tried to recreate this beavior since it doesn't happen often and the solution is simple; Just delete the oldest flat pattern view and you're good to go.
Huysmans Metalen n.v.
2x NX1867 Mach Designer
on Win10 64bit
NX Beta Tester with focus on Sheet Metal
Command Finder is your friend
