2D centerline Extension
 Hi, I have a question
I want to change Centerline Extension in NX10..
How Can I change centerline Extension ??
I already tried from Customer Default - Setting and restart NX
But It was not changed... when I created View.
plz Help
yjnoh@cadians.com
Re: 2D centerline Extension
@yjnoh
By changing your customer default your part preferences are not updated.
Check the drafting preferences of your part.
If you want to change this for all new parts you need to update your drafting template part.
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
圆柱延伸 – 为圆柱中心线的延伸支线输入值。在创建自动中心线时,该值没有效果,相应的用户默认设置也没有效果。该值只有在编辑现有中心线时才有效。
 希望帮助到你,版本NX12.0
