11-24-2017 04:34 AM - edited 11-24-2017 04:37 AM
Hello everyone,
Can anyone know, why the 2D centerline has a different thickness and colour value? When I want to place a centerline, does it have a different style than the one set in Drafting Preferences. In that case, from where the 2D centerline import style data?
Best regards
Jack1
Solved! Go to Solution.
11-24-2017 06:16 AM
Hi @Jack1,
In the customer defaults, you can customize the drafting standard for it.
If you find the width and color in the drafting preferences different than that of in the customer defaults settings, you can use inherit menthod from customer defaults.
Ganesh
#IngenuityIsNX | NX - What's New
11-24-2017 07:07 AM
Thank you, its working
