3DConnexion SubPart moving within NX Assy?
How to toggle on sub-part moving in Assembly for the 3DConnexion devices?
In other CAD systems there ADDin Menu had more options...
Sub-Part moving allows you to opt for the ability to select a part within the assy and move it not the entire view.
is this supported in NX ?
Matt Johnson
Teamcenter 10.1.7
Re: 3DConnexion SubPart moving within NX Assy?
I recall doing that, back in the days of yore, but not in recent history.
-Dave
NX 11 | Teamcenter 11 | Windows 8.1
I contacted 3DConnexion.   They confirmed that at this time sub-part moving is not supported for NX.
I submitted ER 9067676 to GTAC as 3DConnexion advised that the AddIns are owned by the CAD vendor.
Matt Johnson
Teamcenter 10.1.7
Gears Legend Gears Legend
Gears Legend
I just joined your ER Smiley Wink
Huysmans Metalen n.v.
2x NX 11.0.2.7 Mach Designer
on Win7 64bit
NX Beta Tester with focus on Sheet Metal
Command Finder is your friend
