A topology optimization issue
Hello.
During my investigation I have faced a problem.
I tried to apply topology optimiztion for a steering knuckle desingspace. Can CROD elements crash the solution? I ask this, because when I run the solution without ones it complites correctly(pic 3). As I add CROD elements (pic 1) the solution have a fatal error (pic. 2). Can you suggest what problem is?
P.S.
Could you recommend a kind of a User's Guide for topo optimization? I found only a "Design Sensitivity and Optimization User's Guide" where tolds about a topo optimization only a little. Or may you may suggest a youtube channal, etc.
Re: A topology optimization issue
Hi @Xspaner2,
Please open an Incident Report with your local GTAC support office and have them review the results that you have observed.
Regards, Ben
