Activate and Deactivate a Hole under condition
I am a new user of PLM community.
Is there a posibility to activate a hole when a user's variable is "true" and deactivate the same hole when the variable is "false".
I tried to do that with an expression but I don't find the solution. Should I use another solution ? Perhaps with journal or programming ?
Thank you for helping me.
P. Serré
Re: Activate and Deactivate a Hole under condition
This is exactly what I was looking for. It works perfectly.
Thank you so much
