Add Component Array (NX8.5) vs. Pattern Component (NX11)
NX8.5 Assembly:
Add Component Array
When using this command it automatically links new parts to a current Array/Pattern in Existing Part.
NX11 Assembly:
Pattern Component
When using this command we must manually input Pattern Count and Pitch.
Did we lose the ‘Add Component Array’ functionality from NX8.5????
Re: Add Component Array (NX8.5) vs. Pattern Component (NX11)
Siemens Genius Siemens Genius
Siemens Genius
Component Array  is replaced by Component Pattern using Reference Layout option.  A short video is included.
(view in My Videos)
Thanks JGray and Mike Fdo.
JGray had the answer I was looking for.
