Add density attribute in assembly navigator
I've assigned material to all parts to my assembly. Then density attribute is popolated in the part. This attribute I've added in the assembly navigator column but it's not populated without value.
Exist a method to show density attribute part in the ANT ?
Thank you...
Using NX11 and NX1847
RuleDesigner PDM
Re: Add density attribute in assembly navigator
This is a current limitation. ER 1718543 already exists for this functionality.
Regards, Ben
