Adding Components to Assembly Looks Terrible
Hey,
I was wondering if anyone can help me figure out why when I add components to an already made assembly, the new models look really bad. It's shown below in red, and looks like someone drew them. Thanks.
Re: Adding Components to Assembly Looks Terrible
Not sure what you mean by "looking terrible".  I assume that they you've highlighted them, correct?
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
I don't know why NX does this. However you can fix it by going to:
Menu>Preferences>Visualization>
Switch to the "Line" tab in the menu. Then under "Line Widths" hit "Reset to Defaults". Or type in your desired Pixel Widths manually.
I hope this helps.
