Adding Rev.changed [X] tags to drawings ?
Adding Rev.changed [D] tags to drawings ?
Added 6 pcs holes and made a revision D of it...
Now instead of placing [D] tags all over the picture like below...Is there a simpler way to point out I made these 6 holes instead of just placing a lot of these tags.
Re: Adding Rev.changed [X] tags to drawings ?
If you are using a balloon as the revision tag, you could add multiple leaders to the tag and point to the holes you added.
