Adding a same part to assembly by mirroring it ?
Hello
How to add another same part to assembly by mirroring it ?
- Is Assemblies->Add the only choice ?
- Or is there mirror existing piece option that does not create a new part name ?
Re: Adding a same part to assembly by mirroring it ?
As of today the only option to do this is to add the same component again to keep the part number the same.
Scott
hello ,
hello .
i would say, you can use Mirror assembly as an option to add the same component ,only if you want to add the component by mirroring
