Adding another assembly part to main assembly
So I'm assembling a complicated part and I've added another assemblies to my main assembly. However, these other assemblies act like a solid body and doesn't behave according to their constraints. Is there anythingI can do to fix this? Is it possible to un-assemble these parts but keep their constraints in the main assembly.
Re: Adding another assembly part to main assembly
Check 'Position override'.
Ganesh Kadole
Thank you so much for your both quick and correct answer! Appreciated!
