Adding attribute search in Assembly
Is it possible to search using an attribute in the "add" dialog in an assembly. NX/TC has a bunch of default default search parameters, but do not include the attribute that I want to search with.
Re: Adding attribute search in Assembly
Hi @alpinashark,
Unfortunately you're stuck with the ones that are available in the Columns list when you right click in the listing window.  This would be a good candidate for an Enhancement Request (ER) - please consider opening an IR with GTAC to have them submit a new ER for you as I could not find any existing ones requesting this functionality.
Regards, Ben
