Adding "owner" and/or "last modified" to ANT
Is it possible to extract the file owner, and last modifier, from Teamcenter, and display it in the ANT?
A previous thread here discussed, and explained how to add the last modified date:
https://community.plm.automation.siemens.com/t5/NX-Design-Forum/Last-Modified-Date-column-required-i...
Looking thru the docs, I don't see anything that tips me off to the "owner", or "last modified by".
https://docs.plm.automation.siemens.com/tdoc/nx/11.0.2/nx_help#uid:index_tcint:id1299676:tc_nav_add_...
-Dave
Re: Adding "owner" and/or "last modified" to ANT
Hi @DaveK
Try adding these:
  • last modifier: last_mod_user
  • file owner: owning_user
Regards, Ben
Looking back, this is how we did it, and not with TC_NX_ADDITIONAL columns.
https://community.plm.automation.siemens.com/t5/Teamcenter-Administrators-Forum/Mapping-modified-dat...
Would the TC_NX_ADDITIONAL_COLUMNS method be better?
-Dave
Hi @DaveK
That depends on whether you want to capture the values of the preferences as part attributes.  See my reply in the forum you linked to above.
Regards, Ben
Any other suggestions for goodies I can offer up to the ANT?
-Dave
Ok @BenBroad what did I screw up?
My ANT columns are available like expected, but empty.
This is what Teamcenter looks like:
-Dave
IIRC, you'll need to right click in the ANT and choose "Refresh Teamcenter Information".
Regards, Ben
doh...  thanks!
-Dave
