01-24-2018 08:17 AM
How can I add additional balloons manually?
- A second baloon to a already ballooned object in another view
- A balloon with partnumber or partname instead of partslist position number
regards,
Urs
Solved! Go to Solution.
01-24-2018 09:12 AM - edited 01-24-2018 09:17 AM
Hi @ursus,
Create manual balloon in required view and using the object attribue you can have same callout number as it in another view for same component. See the attached video.
About part name in the balloon, you can define a string expression with formula 'ug_askCurrentWorkPart()' in each part and it can be used to insert as a text in manual balloon. Text > Relationship > Insert Expression > Link to Part. Consider the balloon size, length of part/component name.
Ganesh
#IngenuityIsNX | NX - What's New
01-24-2018 07:57 PM
01-25-2018 08:54 AM
Thank you for the video.
I hoped for a slightly fancier solution (pick the component and choose the attribute).
Now quite a few clicks are necessary.
However...it is a solution that will do the job.
best regards
Urs
10-19-2018 04:09 AM
Thanks a lot for the video!
I had same problem.
If to look at user-friendlyness, I expected more elegant solution (most of CADs can automatically attach number from parts list to balloon). At least it works..
