Align assembly to global workspace
NX 10, TC 10
Somehow during the re-constraining of an imported assembly, the entire assembly became mis-aligned to the world in more than one direction, in other words, by a compound angle.  It is also a great distance off of global 0,0,0.
I was wondering if anyone knows of a method to rotate and move the assembly so that it is square to the world.
Thanks.
Re: Align assembly to global workspace
What about create Datum CSYS - "Absolute CSY" and constrain the assembly with it? I guess it should move the assembly in 0,0,0 . But you have to turn off all "Fix" cons.
Thanks.  I will save this suggestion and try it next time.  We ended up re-building this assembly correctly.
