Any tricks to export PMI light weight section view to PDF
Currently, if you export a PMI lightweight section view to PDF ( File->Export->PDF), it doesn't export correctly. It shows the unsectioned geometry ..[ all of the foreground geometry is seen ]
Are there any settings/ preferences we can try to get around this problem?
Re: Any tricks to export PMI light weight section view to PDF
This could be a work around but you could process it down into drafting.  Create a base view in drafting using this light weight  model view for your base view.  Change your view from wireframe to fully shaded.  then you can export this out of drafting with PDF.  I know you want to do this from 3D.
