Approval User map attr
Hi there,
Anybody knows how to map approval user like a approval date?
I tried copy this:
"Approval_Date" : ItemRevision.Job.SIGNOFF(Designer).decision_date /master=iman /description="Approval_Date"
And map this:
"Approval_User" : ItemRevision.Job.SIGNOFF(Designer).decision_user.id /master=iman /description="Approval_User"
But it isn't works.
TC 11.4 | NX 12.0.1
5 REPLIES 5
Re: Approval User map attr
I tried copy this:
And map this:
From what I'm reading, the correct syntax (for NX 12) appears to be:
"Signoff_User" : ItemRevision.Job.SIGNOFF(<release-level-name>,<role-level>).group_member.user.user_id  /master=iman /description="Signoff user"
Regards, Ben
Hi @BenBroad
I've been using the syntax below:
"Signoff_User" : ItemRevision.Job.SIGNOFF(Designer).group_member.user.os_username /master=iman /description="Signoff User"
So it worked fine, but now it doesn't works and I don't know why, I read again your answer and I don't know what is "release-level-name". Could you explain me?
Bauler
NX12 | TC 11.4 | Win10
Hi @bauler,
What happened between when it worked and now?  For example, did you upgrade Teamcenter or NX?
Regards, Ben
I only created a new role on Engineering Group. So this group have two roles "Designer" and "Engineer".
It's the name of the task that was reviewed.  For example:
"MATERIAL_SIGNOFF_USER" : ItemRevision.Job.SIGNOFF(Requirement Review,Designer).group_member.user.user_id  /master=iman /description="Materials signoff user"
"CHECKER" : ItemRevision.Job.SIGNOFF(Checker Review,Checker).group_member.user.user_id /master=iman /description="Checked By"
Does that help? Regards, Ben
