Assembly Clearance - Clearance Browser Columns
Is it possible to change the "Interfering Component" column in the Clearance Browser to show Component Name instead of part name?
In the example, we are doing a Clearance Analysis on a mounted circuit board and a cover. It would be much more beneficial if the generated report gave the Reference Designators (Component Name) instead of the part names as each part might be used many times.
Re: Assembly Clearance - Clearance Browser Columns
Try this: (Courtesy of Ben Broad)
"You can change how the components names/numbers are displayed in the Clearance Browser by selecting "Preferences -> Assemblies -> Descriptive Part Name Style".  Change it from File Name to Description or Specified Attribute and enter "DB_PART_NAME", or your attribute of choice.
Repeat the Perform Analysis command to update the Clearance Browser.
