Assembly attribute in the title block
Is there an attribute I can reference or other method to insert the parent name in the title block of a detail part?
e.g. In the title block of a detail part one might have....
Part Name:  pname
Scale:  1:4
Assembly: assyname
where pname is a component of assyname.
I understand this could cause problems where pname is used in multiple places, but for my purposes the parts are highly specific and are only ever used in one assembly.
Re: Assembly attribute in the title block
Information is saved in the assembly file about what components it contains, but no information is saved in the part file about what assembly it is used in.
Thanks.  I was hoping there was a way to reference or link an attribute from the parent part.
In the assembly file (assy.prt) create the string expression:
AssyName=ug_askcurrentworkpart()
In the component file create the string interpart expression:
ParentAssy="assy"::AssyName
Use the "Category: Relationships" option under the Symbols section of the Note editor to use the interpart expression in your title block.
Regards, Ben
