Assembly dimension in MB
Good Morning,
I have a part file whit geometry, it less than 20MB,
I need to add some components to this part ( around 10 parts in assembly).
Now the part is around 350MB, no geometry added, only parts in assembly tree.
It's normal??
Greetings
Speziali Bruno
3 REPLIES 3
Re: Assembly dimension in MB
Hi @Speziali_Bruno ,
Please go through below discussion thread. Multiple options to reduce the file size are mentioned there.
This might help.
https://community.plm.automation.siemens.com/t5/NX-Design-Forum/Downsizing-of-model-size/td-p/406761
Amol
thank you but is not my case.
My model it's very light it a 35m boats whit all radius and after a cleanup it's only 15MB.
I have the problem only if I add the components on this file....seems that new components add something to parents, but I don't have any new geometries. 300MB of preview image I think it's no possible
Finally I solved,
there is something corrupted in primary part file. I saved the geometries in a new file and  I delete all geometry in this file and I saved....It still remain around 300MB...
So I created a new part empty, imported the geometry and now I have a 15MB file, and after I added parts in assembly tree the weight still reamain around 15MB
