Assembly loading time
hi
how to reduce the loading time of big assemblies particularly while doing drawings ?
Re: Assembly loading time
Try using 'Use Lightweight Representations' and 'Use Partial loading' on your load options. It may help.
hi
already tried those options still it was tacking huge time for loading & placing views
Did you try turning off the 'Load Interpart Data' and 'Generate Missing Part Family Members'??
is this for creating a drawing or edit/viewing an drawing?
if it's for edit viewing you can maybe also use extracted edges.(view prefereces)
when this is on you can view your drawing when your strucuture is only loaded.
For updating your views you need to open the compleet assembly
Ruud van den Brand
Pre-sales NX CAD
cards PLM Solutions
